Swithcbacks on 04+
rhenuset
I got switchbacks for my 06 gt and have read lots of threads about switchbacks but can only find stuff on the older gps which doesn't solve my problem. a buddy gave me some 6ohm 50watt resistors so i tried those in many different configurations and the switchbacks wont even power on. without the resistors the switchbacks work fine but then i get hyperflash in the back. anyone know if i have the right resistors and what wires to tap into?
Number one if the bulb doesn't even power up, turn the bulb around, they are polarity sensitive. And yes you have the right resistors, you tap into the ground/black wire and the turn signal power wire. I can't remember what color, I'll check when I get home. I have switchbacks and have no problems in my 04 which is the same setup
I work at gm and have been having trouble finding the right schematic. Alright I will try that tomorrow and see. I dont know if my wire colours are dirty or what but I believe there is a black, brown and red wire going into the turn signal and then a black going out of the turn into the fog and so on. So the ground I tap into is the black going out of the turn signal?
Yup, it's a common ground for turn and fog I believe. Haven't had a chance to look at mine, will tomorrow
Forgive me for digging this thread up from the grave but, I'm having an issues as trying well to figure out which wires to tap the load resistors into to stop hyperflash with turn signal LEDs . Very confused. There's a blue wire ,purple wire (fog light), brown wire , and the ground/black wire goes from the harness through turn signal socket then back out to the fog. Ive spliced the resistor into the ground/black section coming from the harness clip and the brown wire and my LEDs still had hyperflash. For the good of the 04+ gtp's(as there is already fixes documented for 03s and down) can anyone tell me the correct configuration for the load resistors on 2004 gtp with the shared turn/fog lights . Would have kept trying but batteries died on me and it takes some days for xspower batteries to slow charge ��
