Direct fit.. Nope unless you switch to the 97-03, 06-08 style control arm and end links then you can that swaybar or get a solid dorman one, it won't fit without.
the sway bar style changed for 2 years, the odd ball end links hook to the strut, not the lca's.
if your end links bolt to the strut, you need to check to see if your lca's have the perch for the sway bar end links or change the lca's so you can use the different sway bar.
this is a dorman 33 mm solid bar with end links to the lca. look for that perch on the lca.
Where would I get something like that?if you go with a custom heim joint arm/link you could use the earlier style fatter bars with the strut
Sent from my SM-S820L using Tapatalk
