Is the sway bar on the 05 Impala SS the same as the GMPP sway bar and are they both hollow.
I just put brand new Moog bar and poly end links. Will they work on doorman or will bar bushings be to big.
Sent from my SGH-M919 using Tapatalk
Dorman is the same size as the GMPP bar.. Difference is solid vs hollow.. If your going to buy another swaybar buy a Dorman! Yes the bushings and poly will still work
I'm purchasing it from Advanced Auto, I have a $25 off coupon I need to use before July 7th.The Dorman bar is good, had it on my GTP. Used it along with some cheap poly bushings myself. No problems at all.
You might also choose to buy on advance auto's website and pick up in the store... you can use TRT30 for 30% off, which should save you $33. Alternatively, TRT41 will knock $40 off, but you have to add something to your order to bring the initial total over $100 (bar is listed for $99.99, so you can buy a small tube of grease or something).
Retailmenot.com
Order online, if the option to pick up in store is available then do it, for my sway I had to have it shipped. In that case getting the order total to $75 so you'll get free shipping, you don't want to pay shipping on this swaybar if u can help it. If you have to add something to get your order to the $75 mark, shoptowels are always a good choice, I do this most of the time and have boxes and rolls around that I use constantly or if you need something within a few bucks, dielectric grease/air freshners/brake cleaner etc.
