I would try those 42's before buying new ones, if you don't run E85 they will be plenty, and even if you do run E85, they will have a decent amount of head room. I had a 3.0" pulley on last week with my ported heads and XP cam with E85 and the injector duty cycle was at 80%, since then I have gone back up to the 3.2" pulley and am at 70% duty cycle, now it is winter time, so the ethanol percentage is 70, so in the summer I might be closer to maxing the injectors, but they still might be sufficient.
I would imagine those injectors will work, but depending on the wire harness you have for the engine, you might need injector wire harness adapters. 97-03 used the EV1, 04+ used the EV6.
