Okay guys so I redid a good amount of my suspension... and I apologize for not taking pictures beforehand but I was so obsessed with getting this stuff on I forgot to take pics... A good friend helped me out and we did this stuff in about a weekend's worth of work
Here's what's new:
-Delco replacement control arms w/ Moog's problem solver bushings
-OEM junkyard front sway bar (28 mm) w/ energy suspension bushings and new links
-Rear ADDCO 22 mm solid bar w/ urethane bushings that came with it + Duralast links
-KYB GR2 struts all the way around
-Vogtland FRONT lowering springs 200# as stated in the forum (been almost 2 weeks, settled maybe a quarter to a half inch)
-WBS REAR HEIGHTENING springs 350# as stated by WBS (settled a little, about a little higher than stock, maybe an inch, probably less)
-ZZP shortened dogbones w/ poly motor mounts - Not yet put on
-245/45/17 Kumho Ecsta 4X II
Vogtland front springs
Rear ADDCO bar
Rear WBS springs
Front sway bar w/ new links/bushings
How the car sits as of now
Again, sorry for the bad images, like I said I was so obsessed with getting these parts on I didn't bother taking pictures, I had to go to a shop to get the new LCA bushings pressed in but other than that rust was a MAJOR issue, almost made me want to quit at many points
Other than that Mods still needed:
-Need to put on Dogbones/Mounts (already own)
-Need to buy the biggest front brake kit available and possible w/ the +32 offset 17" Mustang wheels
-Need to buy trailing arms and lateral arms
-In desperate need of a driver's mod, I'm learning to drive this thing all over again (Most major one here)
-Need any power mod, I want a turbo conversion when I have some money, I feel like a blower is the wrong kind of boost for a car setup like this... would love the precision 6262 kit from ZZP detuned to close to stock power
-Need transmission build before I get more power, hence IF I do the conversion first I'll have them tune it to about stock power or maybe a little more (210-220 whp would be lovely), but most likely will do trans build first and go straight to about 300 whp
Feels/handling
-The ride is stiffened up a little but it's still fairly decent... but there's no way of getting around it, the shocks are way to soft even for the Vogtlands
-The OEM front sway bar is too soft, at highway speeds the rear will want to overtake the front with aggressive lift off or trail braking (NOT SAFE!!!), I thought with the energy suspension bushings up front the sway bar would be 100% effective and stiffen the front up a little, but the front rolls still a bit too much, the front roll reminds me of maybe like a stock previous gen WRX.
-The rear end is very very tight and under hard trail braking the rear tires WILL lose traction, for example I braked a little too late in a corner today and the rear tires actually started squealing, the first time I heard these tires squeal on either end.
-The car is VERY responsive, the problem solver bushings probably made the most difference out of anything, the car LOVES to take a turn and it almost assists you in corners... the responsiveness is like no other 90s car (yes I know it's a 2002, but that's besides the point)
At first I was very skeptical of the handling, I even made a thread about how I didn't like that the rear tires wouldn't budge when I lifted off the throttle. But I was wrong about this car and all it needs is a driver's mod (and maybe a stiffer front sway bar)... this thing is surprisingly fast around corners and the tires provide incredible amounts of grip. I might be wrong but I'm pretty sure the Ecsta 4X II are one of the best A/S perfromance tires on the market, I assume this car grips as well as an older 328i like an E46 or something (should be about mid .8 Gs). I'm sure this will run circles around any stock OE GP fairly easily and I'm sure it's on the level of say a Cobalt SS. The front bar does not provide adequate roll resistance though... even with the polyurethane bushings it doesn't seem like 28 mm hollow is enough. I did want the front to have a little bit of roll so the rear end is stiffer, at least slightly. Most likely I'll have to order a Dorman bar.
Oh PS Does anyone know which bushings to use with the 33 mm Dorman bar? Can I possible reuse the bushings I bought for the OEM one?
Here's what's new:
Rear ADDCO bar
Rear WBS springs
Feels/handling
