Supercharger pulley came off
ssielsnop guy sells rebuild kits on ebay.
a used blower is so much easier tho. gen 3's are pretty cheap these days. gen 5's are still up there but under 300 most of the time.
Also there is a place here locally that makes bearings, called industrial bearing supply can I go that route I know it'll be cheaper
Sent from my SAMSUNG-SM-G870A using Tapatalk
heres a trophy for your efforts
Got a rotor pack coming just in case $35 shipped guy says there's no play n the coating is still on it
I got it just in case it looks way better than mine did a year ago..n for $35 can't beat it
I've had heard mixed opinions on it... You can do it. I have soo many gen3's here I've Frankenstein'd a few.
The points I've come across are as follows
- if the rotor pack had any issues or play in it it could have worn the case and the new pack won't seal as tightly
- another was that the rotor pack and housing conform to each other making the seal, so changing either component would possible change this bond between the 2
