nvrstsfd23
I was driving my 99 grand prix gtp and the supercharger belt shredded from the idler pulley burning up. The belt got wrapped around the inside of the pulley on the s/c and now its leaking oil our of it. Where do I get the seal for it and do you just use a puller to remove the pulley to get to that seal. Also I figure I need to replace the rest of the pulley's that are in question. I seen the tensioner under the coil packs to change that, the idler pulley by that, the pulley on the other tensioner by the alternator. How do you tell if that tensioner is good or not. Also what other pulley should I look at the crank, ps, alt are all good and tight. There is a pulley right under the s/c pulley. Should I replace that one as well it looks like it attaches with four bolts. Thanks for the input and your time
