Hey I want to know if anyone has tried to make a series II supercharger work on the newer series III engine???? I think im about to give it a try any tips or thoughts would help!
You would have to make a stud system for the Gen 3 S/C and make it to where the nut's are countersunk all the way into the spacer/adapter. You have to do this because the mounting surface for the Gen5 is smaller than the gen 3.From there you would need threaded holes for the DBW TB to bolt up.
It would take some machining but nothing more.
Or you could just buy an aluminum adapter and bolt the DBW TB up to the spacer. Then drill through the threaded holes on the spacer to allow for the studs or bolts to pass through into the gen 3 S/C
