Sun roof gasket leaks
GrandpaAl
Evening guys! Besides the dealer, where do we go for the gasket that the sunroof seals to. I found mine leaking after running it through the carwash today. After 93k the little ridges the glas seals to are flat.
i got mine from the gm dealer, $150.00. Make sure your sunroof glass itself is adjusted properly, and the drain tubes are cleared out.
btw i have a thread on my sunroof problems if your interested. It's in the grand prix section at the bottom.
......and why is this in the motor section? Junkyard would be an alternative to dealer but obviously it is used. You could also go to a dealer, get the part number and get it much cheaper at gmpartsdirect.com.................Ed Morad might have a used one as well....
Very good, I'll check out thread before going to the dealer. My Helm service manual arrived today, check that too. Thanks.
