Subway's GT: Time to close my legs, it smells everywhere
Re: Jared's 2001 GT
Let me explain trans fluid to you.
It's a detergent based oil, much like your engine oil. It is intended to be changed about every 30K miles, much like your engine oil except less frequently. Within that 30K time frame the filter does it's job and the oil gets dirty etc, much like your engine oil except on a different frequency.
Didn't know this I thought I'd get 50k out of it guess I'll add this to my upcoming service then!
Re: Jared's 2001 GT
So I planned on buying Reptile's tune in a month or two so I can pay for the important stuff like plate renewal, tires, etc. But since my fans are still programmed to 210* or whatever the stock temperature is, my 180* T-Stat is almost pointless (imagine that). It sits nice and low when driving, but once you sit there, it will climb. So I might have to get that tune earlier than I thought. But after taking my air box out and seeing the PCM sit there, how do you take it out or disconnect it? I didn't get a good look at it, but I imagine the wires aren't clipped in like a fuel injector wire, so how do you take it out?
Re: Meatball Sub with Pickles
Well if you're sending it in, there is a bolt holding the connector the ecu. It's in the center.
