Getting a bad clunk on accelerating from a stop and when shifting into reverse and drive. Replaced sway bar end links, trans mount and mount bracket (was rusted to hell), and control arm. Suppose i should check the motor mount, but the trans mount didn't look bad when I took it out. I can't see any other visible problems. I've read around and some people have said subframe bushing could be the culprit for clunks and knocking. Others have said these rarely go bad. My question is, if I were to replace them, are all four the same?
I see on rockauto they have this set: http://www.rockauto.com/catalog/moreinfo.php?pk=1534260&cc=1429691&jnid=478&jpid=0
Do those parts 'assemble' to create one bushing? Would I then need to buy four? Or are they not all the same (ie different ones in front vs back).
