Stuck in park! Cant push shifter button!
01STOCKGTP
So the other day drove my car to a restaurant and when we came out to leave i couldn't get it out of park... the shifter button on the knob wouldn't push in. Since i had heard about this problem before with gps i just used the shift lock release button the next couple times i had to drive it. My key hasnt gotten stuck like i have seen on here as an associated problem.
Checked my BTSI fuse......Checked to make sure i had brake lights....both were fine.
So i did what any broke ass college kid would do and took the center counsole apart and rubber banded the shift lock release lever all the way open so i don't have to push the button every time.
The only problem is now my shifter could potentially be bumped into reverse or park going highway speed because i basically took away that safety feature!
Any ideas what could be wrong and how to fix it for real with something other than a rubber band? :th_laugh-lol3:
Did you check at the soleniod for power! How about listening for a clicking from it!
Nab a picture of it! I've seen on my own car where teh white piece that would be pushed from above to release it can jamb up!
Havent checked for a clicking. I do know that the while plastic piece doesn't move when i push down the brake. It moves easily with the shift lock release which i have rubber banded engaged
You still have to squeeze the release to shift it into Reverse or park. At least that's how mine is and I've had it rigged for 2 years now.
So as long as you can control the urge to throw it into reverse or park u should be good
ill have to look into this myself, i've been doing the slap chop on my shifter to pop the release down, the white button dont do dick to release mine, and ive had the console out 4 times since august and its been cold and i dont want to deal with it.
thank god the ignition release worked, friggin dead battery cough me off guard.
im pretty sure i don't need to push the button and can just push it forward when driving. I put the parking brake on while in drive and could just push it on forward into reverse then park with no button....
scary!
man im glad mine has reverse lock out, you need to push the button in to get it into reverse or park.
regals rule...just kidding:th_peaceout:
do you mean the actual shifter knob button or the shift lock release button?
because im prty sure we all understand that mine is held open as is yours correct?
my release button, that you would use to bypass the shifter button if the button failed dont do nothing, i have to slam my hand on the shifter knob to get out of park.
but once its in drive i have to push the shifter button to get to reverse or park.
its only frozen when in park, after i slam it and go into gear it works.
are you saying that you have the shifter button rigged to stay down all the time? now that would be scary i must say.
Ya it was real simple to do. I took out the center counsol and simply looked what the shift lock release button was doing. it pulls out the white plastic disc on the cable allowing you to push the knob button and shift like nothing was wrong.
It is kinda scary. Car off, Keys out, I can put it in any gear even without using the brake.
This is the whole reason i posted this to see if im a complete idiot for disabling this safety feature... no doubt it isn't strickly legal
ok then lol im going to pull mine apart and try to fix it the right way, i may have a wire pulled off or something easy, i've had the console off so many time i may have pulled something out of place and it worked it way off over time or something, thanks.
Regals do rule!
I pulled the white piece off ...or well..it fell off. Meanwhile my shifter works totally normal w/o it.
C'mon man..it's at least 50 out... rainy and sucky..but all you gotta do is smile at the neighbors when you get outta the foggy window car. They'll wonder what you were doing in there. :D
My neighbors don't even bat an eye at that stuff anymore. They just accept whatever they see as "normal" for me.
im living in an apt building, they dont let anyone work on there cars in this lot, i was waxing my car and was told to do it else where.
since im here ive done a full tune up, full brake job , disks and all at stop and shops lot, replaced a heater core in the park, new power ports in pep boys lot, removed my struts at a friends house who lives around the corner from a front end shop to get new mounts put on, and so on lol its been a real trip living here, I MISS MY GARAGE DAMN IT!!!!!!!!
and now ill be doing side view mirror replacement due to some ass busting it for me!!!!
I'm a quick spin up the road from you. Stop on over if you wanna borrow one of the garage bays.
Close is relevant... I have friends that come from Ohio ....lol
thanks bill, jersey is closer than ohio lol , im trying to get a house in tuexedo ny tax problems keep f ing me and my girl over still, but its got a 4 car garage, 2 cars deep and 2 1/2 cars wide, its a heaven i'll just have to wait for.
