stuck in dallas
98gtpne
so i drove down to dallas yesturday from omaha nebraska and half way here i added 6 gallons of 89 octane and shortly after that it started missing and hessitating realy bad and i was told it was because i had a 3.4 pully and ran lean so i ran it low on fuel and filled up with 91 octane and octane booster well it was still doing it so i filled up once again with 93 and it used to only do it under wide open throttle and i check the codes it says missfiring in cylinder 4 so i have changed the sparkplugs and the wires and the coilpack and i did a fuel check and it never got 40psi so only opton i can think of is bad fuel injector? anybody have any ideas, im here visiting famiy and limited on tools and time before i have to drive 600 miles home need advice please
my advice, just stay there. its GOTTA be better then where you came from (i live 35 miles north of you)
never got over 40 psi? Same with driving as well? If so you're fuel pump is gone... I had the same issue on my black car
