darkhorizon
I already told you.
Measure cylinder bore.
After you tear it apart.
because that will tell you what crankshaft is in it...... right....
I already told you.
Swan Racing's domain/page is gone.
Le fail.
They were the only ones to make a worthwhile kit, it was just expensive as hell.
Like slow said...only way you're going to really find out or not is to pull the engine and rip it apart and measure the cylinders wall to wall.
He previously asked if the cylinders were bored.
That's what I was referring to.
I was thinking about that as well since stock rockers n pushrods aren't hard to come by. And most likely do the lifters as well.Motor doesnt sound blown particularly... You would have some very glittery oil if you were ****ting rod bearings.
I would put some stock rockers and pushrods back on it and see what happens.
Never did ask that I just wanted to know if I can take off the oil pan and find out the necessary info from there instead of taking off the heads.
*reasons to not buy modded car*
Blown motor.
Looked like some exhaust might have slipped out at the front header gasket, too. I see what looks like a puff of smoke at 6:46.... or something reflected sunlight into the engine bay. Hard to say. Either way, just buy some new headers. If it's got one hole, it's bound to make another.
