Strange rpm wobble and CEL flashing
OZZY1123
I'm driving a 99 Grand Prix GTP with the 3800 series supercharged engine, the other day I was driving down the highway, not incredibly fast, maybe 150km and my check engine light came on and started flashing. I stopped and started looking for problems under the hood and checked the gas cap. Everything seemed to be fine so I continued driving. Nothing seemed to be incredibly out of whack so i have since let it be. The only thing I have noticed different is that if I punch it, it will rev to about 3100rpm then sit there and keep accelerating, then it kind of drops a bit and takes off to 4000rpm where it sits again the same as at 3000. Today I noticed when it was at the 3000 range the car jerked slightly but nothing that seemed to be a real threat. As I was looking for solutions i found a few suggestions saying it could be an air leak, but it idles fine so I am not sure thats the problem. I have also read it could be spark plugs or coils but I would like to know for sure before spending money on that. I should mention that during the summer it had a problem with sparkplug gap and I had to have it towed as it would not even idle, could this be the problem again?
Thanks
Austin
Flashing SES light means catalyist damage, as in misfires.
I would try and figure out which cylinders are throwing the mis-fire and go from there. You may have other codes should up aswell.
I forgot to mention that the SES light is on constantly until it gets into that 3-4000 rev range for a few seconds then it starts blinking. Is this normal?
no its not. go to your local parts store and have your car scanned.
the flashing is bad, its telling you to stop doing what ever your doing. most of the time flashing light is multiple misfires, or a clogged cat.
it could be as simple as needing tune up real bad.
Is it ok to drive it like this as long as the light is not flashing? Everything feels fine until its almost wide open
if you have no choice but to drive it, baby it, dont make the light flash.
get it scanned and fixed asap tho. dont let this go for to long. flashing is warning of a catastrophic event happening. aka not good at all.
just fot the car back and turns out it was a misfire on cylinder 3. Plugs were replaced this summer after a gap issue but wires were not and that seemed to be what was causing it. Plug and wires were replaced and everything seems to be good. Thanks for all your help, I am loving it here on the forum!
Austin
