Strange noise from front wheel
abuckley1290
Today my car started making a grinding noise coming from the front left wheel. It sounds similar to worn break pads (metal on metal grinding) and only happens when the wheel is turned pretty far to the right (high and low speeds). Any ideas what it could be? Its not a steady noise but it repeats more the faster im going
^^ That is what I was thinkin...or maybe a part of the CV Shaft? And yes...part of it...mine was in a few pieces when I pulled it out LOL
How would i check for the cv shaft? I put the car on a jack with the wheel turned all the way to the right and the front left spun freely so idk if it could be a sticking caliper
bio is right its probably the wheel bearing fa sho. mine only did it when i turned right then it got to the point when it did it just driving straight. got mine replaced a couple weeks ago
check the boots of the cv shaft really well. if you got a hole anywhere, usually evedent by grease on the boot, then your buying a cv shaft
