Leiliel666
the module piece that screws on top of the pcm? what does that do if i rearrange them?
i have some spare coils off of one of my old cars. ill swap em on. the coils are bright red and the wires are zzp brand. ive ziptied so many things today... and at wot about 70mph or so 4500rpm it jumps to ten degrees kr *usually and stays there. this is car is maddening
got the delco coils on. dont have any wires layin around that id trust. gonna test drive. wish me luck
Well there's something! Switch em with 606s or Ngk tr-55. Post back with results. If she's breathing clear then the issue to be resolved is with what were discussing I'd say.i just pulled plugs off the front of the motor to check the scoring. the number one had oil on it. valve seals? yeah i hear ya man. im half tempted to write it off as a basket case. i got another car to drive till winter. maybe i can throw it at a shop until they figure it out XD
It's got nothing to do with your ignition.
Check your DP for clogs, but it sure sounds to me like a trashed suspension. I had a problem with an axle causing KR at certain speeds due to it's harmonics.
I never changed away from the factory knock module on the 97 that I used to have, but I was pretty sure it was the LT4 knock module that everyone swapped in.
But, if you are going to swap this motor into a lighter car, I would recommend that you get a 98+ wiring harness and PCM. Some 97's just have bad luck with kr.
