    TIPS:
Stattama Turbo Kit
2003 SSEi
Stattama Kit. This is the hot side kit. This kit came off a car that made 550+ whp.
$2000 plus ship (and open to offers)
Front and rear stainless p-logs
Stattama crossover
3inch Stattama down pipe
Comp CT360 turbo 67/65 turbo capable of 900 wheel with no shaft play
Turbo blanket
Complete upper and lower L26 intake.
Turbo and down pipe and wastegate are all v band
Missing Fuel rail and TB
This kit needs a waste gate boost controller and some hoses for oil supply and return plus cold side to be complete
in the description the original poster says it needs a fuel rail, throttle body, wastegate, boost controller, and oil lines for supply and return. since you already have an L26 car, you wouldn't need a fuel rail, but might need to switch to a different throttle body and maf. you would also need to run a 2 bar map sensor.
pshojo. IF you already have a L26, then it makes it easier.
to complete the kit you would need the following off the top of my head
Misc Vac Lines
V Band Waste Gate
Boost Controller
Oil Feed and Return lines
misc Couplers
and if you wanted to intercool it you would need a front mount kit.
Remember this is a $5,000 kit NEW and this has a more expensive and better flowing turbo than the T67 Stattama.
This is really tempting, I was going to do top swap. If this produces 550hp.. I think my 4t60e won't hold. Can this be tuned down?
Correct, the Kit can be turned down to what ever boost you want to run.
the Turbo is actually easier on the trans than the top swap. Its all where the torque comes in This turbo Is big enough to make monster power, but small enough to be able to get spooled quickly.
There was constant power with that turbo, no lag ever. I raced an 05 gtp that had rockers, from 40 I stepped on it and it was like the gtp was standing still when I took off. I miss this kit...
turbos kill trannys, its proven time and time again. when a turbo kicks in it nothing like a sc at all. more like a mule kick to the tranny.
Lies......Trans behind a mild turbo will last longer than behind solid SC build. There isn't that instant shock load in the trans and is much nicer on hard parts. All comes down the driving styles also. If I were to build another turbo car it would have an almost stock trans in it.....with V8 spec chains.
Tried to PM, your inbox is full.
I'm interested in buying the hotside minus the turbo.
Feel free to send me an email or PM
Thanks,
Andrew
