SS M-90 belt wrap solution!!
That has some serious promise I would think. Very nice dude. Any way it could possible be pushed down even further?
Also, where did you get those ignition coils from?
Yes I could give it a bit more wrap if I went to a 1" longer belt and drilled another hole in the bracket,this was a first attemp so a little experimenting is in order,as far as the coils I picked those up in Canada.Chico.
I asked this over on CGP as well but.... What size SC pulley do you have on there now, the 3.5"? Is that idler 3" or 3.5", and would there be room to use a larger pulley to get even more wrap?
There is probably enough room to use a 3.5 idler pulley,this is just the initial design I will try to lower the pulley for a lttle more wrap.
