srt wheels?
look at the bolt pattern. think.
then look at the rest of the specs. think.
something won't add up.
Ive had Charger 20"s on my gp b4 & they will fit. They are too wide and stick out past the fender well. If I ever find my iphone I'll post the pics.
ah, and i really dont know what size works with what offset, never been good at that thing.
its simple math. as a rule of thumb, if a rim is 9 inches wide, dont go below 35 in offset. if its 8 in wide, dont go below 30. if its 7 in wide, dont go below 25.
Here a pic of my GP w/ charger R/T 20's
Run some nice negative camber & a set of narrower lower profile tires to fix it. Maybe. Look & you'll see the tire sticks out nearly an inch past the fender. Also the 275 wide tire(stock might be 245 idk) was rubbing against the strut top. And the rims hardly clear the sides of the caliper. In fact I think they rub the caliper. Upgrading to a lerger set of brakes wouuld probablyy fix that. If someone wants to try a set of SRT rims & DD them I'd like to see them do it. It is possible.
Can you get more pictures? Or did you only try one rim? Cause the rears look different.
I kinda like them, if they stick out on the fronts, that means they should be close to perfect on the rears.
My buddy was putting halo rings in his headlights. So his front wheels were off. I figured I'd just see if they fit. I only tried the one wheel &.it looks like chit it does.
Pay a butt load of money to have the rims cut in half. Then remove s ome width out of the wheel & weld the wheels back together. Worth it? Idk, but bikers do it.
