My driver's side window squeaks/screeches when I'm rolling it up. Any ideas where I could lubricate the glass? I've tried a percussive fix, but that hasn't worked.
Get some dry lube from Autozone or the like and spray the window guides/channels on both sides while the window is fully down. Run the window up and down a few times and see if that helps. If not, you may need to pull the door panel to get to the rest of the guides.
Ugh, tried some dry graphite and some white lithium down the sides. That's not where the squeak is, so I took apart the door and lubricated the slides that go up and down - that's where the squeak is. Liberally sprayed them with lithium grease as well, tested it with everything apart, no squeak. Put everything back together, test it. Squeak returned... Maybe leaving it for a while will let everything soak and it won't squeak next time I roll it up.
