Spyder halo problems
Brycejhnsn100
I have the cheap spyder halos from ebay...lol and for some reason my passamger high beam went out. I have 5 extra bulbs none seem to work, the wiring is fine. Is their a fuse or a ground or somethig i can check? Im stuck ive tried everything. I dont know what it could be.
Do you have a volt meter? If you do, stick the probes in the connector and see what you get. Should be around 12V. Also check the connector and see if it's not backwards. The connectors can easily be mistaken if you just connect them by how it LOOKS like it will go (ask me how I know haha) Make sure the ground from the plug matches with ground on the connector.
