Speakers going in and out
klj5022
KSteelwheelzJ
I Have an 01 GTP Sedan. My radios used to go out on the drivers side(front and rear) every once in a while. Now it happens quite frequently when i hit bumps sometimes not even from bumps just smooth driving. I have the stock speakers, i checked to make sure that the wires in the trunk were all plugged in and secure. Anyone have any idea? I have an after market headunit with 1 12" sub and amp.:th_question1::th_question1:
For the front driver's side speaker, it could very well just be a damaged wire in the door jamb. You could try bypassing the factory wiring and put some audio wire across the leads on the speaker from your head unit. If it turns out to be the wiring, you can replace the wiring.
I dunno what the failure rate for head units are, but I'd want to be sure the head unit is bad before dropping money on another one.
