Speaker questions
Lishap
Hi i have a 04 GP GTP Comp G...i had a Pioneer AVH-P3300BT head-unit installed and the loudness of all the speakers seemed to drop drastically. I was wondering if there is a way to fix that? and also the rear speakers are blown so i plan on installing new ones but wasn't sure what kinds would be best Im looking for some strong base without having to get subs, Any suggestions? Would i also have to get a new amp for these? any help is really appreciated i know these are probably some rookie questions. Thanks Nick.
Are you using a harness that ties into the Monsoon amp wiring, or are you bypassing that and hooking your speakers directly up to your headunit? People will be able to elaborate more with a little more info.
Go back to where you had it installed and tell them your problems, if they are reputable they will and should fix any issues no questions asked, if not I would look into tearing it apart and see how it is hooked up and what harness was used and then maybe the forum can help you out.
