Spartan GL's Build Thread: (09-21-14) New photos!
Re: Spartan GL's (01/11/12) PG 22 for Engine Status Update Photos!!!
Make absolute sure that they check allllllllll clearances. Also, dont JB weld **** inside the engine, especially if you are going this far into the build. I'd assume you are getting roller rockers, so make sure that the pushrods are to the correct length.
Also, for the "wth is on the heads"....if you're talking about the 1st and 2nd head photos, that should be Valve-lapping compound.
BODY WORK! Side moldings removed and sanded down! and my new door to replace the one my brother backed into!
starting to spray some odds and ends (door handles side mirrors etc... spoiler roof rails etc!)
Re: Spartan GL's (01/12/12) PG 23 for BODY WORK photos.
Also if anyone needs bottom end engine parts let me know
Stock Pistons, rods, timing chain, heads w/e
Everyone, i am in dire need of a HP tuners file to use as a starter that is similar to my build. Any and all help would be much appreciated.
Thanks.
use the maf table for your maf.
use the injector table for your injectors.
command around 14* timing at WOT and run a large pulley to start with.
Large being 3.4.
yep all that cladding still on the bottom of the car? all this paint work and engine work and everything work on this car considering the money going into it not taking the cladding off and painting it seperate and checking/cleaning up behind that plastic cladding on the bottom is INSANE to me!
(you liked my remark last time tho I have no idea why)
molding the doors to get rid of the ridge from the cladding would be a ****************. i can understand why theyre still on the car
i assure you its coming off to paint. he just didnt have it off yet. like the rest of the stuff haha.
use the injector table for your injectors. If you have a rewire, flat IFR table. If you dont, get one.
Also get the injector offset table for your injectors.
Large being 3.4.
I'm not the one tuning it, my tuner is coming down from Daytona and wanted me to find a HP tune file with similar major modifications.
motor flows air.
if the maf and fuel calibrations are on, you shouldnt have to change anything.
No dude you got it all ass backwards not mold them! HAHA I meant take them off paint seperate and then put back on. Makes no sense to paint a whole car with out taking them off I promise you they will have a buildup of dirt in the plastic rocker trim.
I think Spartan finally got it too Id just hate to see a whole car being painted and not see the attention to details like that. Esp when prep work makes or breaks a paint job!
And if there is dirt/debris behind that its all gonna blow out into your paint. Prep is about 85% of the paint process. Almost anyone can spray some paint, but taking all the necessary steps and all the little things in prep is what is going to mean the difference between a good paint job, and you might as well spray painted it type of paint job. Don't cut corners and try to save yourself a cpl bucks here n there, cuz IT WILL come back to bite you in the ass. Might not show up right away, but small imperfections will start showing thru over time!
like i said before.. he is taking them off, they are on in the photo because he was working on filling in the holes from the trim.
Why is everyone going hwrdcore on gbe side.mouldings? Anyways looking good
Kindle Fire: 58 pixels were harmed or maimed in the making of this post. Congratulations on becoming an accessory.
how drunk were you during the posting of that post? haha
"NUBE ALERT"
cladding?
wtf is that?
anyways looking good spartan
