spark plug wire question
copperpacecar
SexyStudmuffin
was showing off motor at night and saw spark coming from all the plug wires at the plugs when i reved the motor. a friend said it was just static discharge and that it was normal. what do u all think?
well idk, but normally that is called "arching" and its usually from moisture being in the boots. Thats why they make di-electric grease to put in the boots of the plugs so they dont do this. a set of PRJ wires was doing this, and it turned the terminal on the coil pack brown.
idk, but check the insides of the boots. i have never seen my wires spark like that out of normality
neither have i as i only noticed cause it was dark out and i saw a flickering light on my firewall and then saw it on all the plugs. i would have been alarmed if not for the fact that all the plugs were doing it. hard for all the wires to fail at one time
yea no thats bad definatly bad definatly check the boots
had an old civic do that once fixed the problem happened to be a bad wire and arched through 2 other wires
then new wires it is...left message for the guy that use to sell/work at the moroso plant but havent got a response. do u all know if he is still selling them?
