Spark Plug tips gone!!! UPDATE 2/6/2011
Re: Spark Plug tips gone!!!
will it make them look like ****?
Well if you install them and put the RTV on them like a 2yr yes they will look like ****....
This my take some work but i would recommended getting rid of that stupid Downpipe that comes with these headers and try to go this route. In some way shape or form.
when i 1st got my car i had a misfire and come to find out the tip on cyl. #4 was gone. but i have no damage to the engine from what i know. he may not have damage. u never know
It's always nice to hope...but with no flow mods and high compression...I highly doubt it.
Pull the plugs and put 103's in it, and hope that the damage was just isolated to plug. Id have a shop bore scope the effective cylinders and see if the piston looks like a dog chewed on it
well yea i understand his reason since he didnt have flow mods but i did. idk where the tip went off my spark plug. maybe ill find it when i pull the motor lol
You won't find it...it'll be burned up in the combustion chamber...what you will find...is a chunk of your piston missing.
maybe the spark plug just got dropped and the piece broke off outside the engine :p lol. i will never know since i bought the car with a misfire and it was that simple spark plug fix
So i am planning on the worst case Here are my new plans
  1. Used L26 Bottom end
  2. either s1x or xp cam
  3. 110# Crow Springs
  4. Double roller timing chain
  5. SD Headers
Any imput would be greatly appricated, i am on a budget!
Skip the double roller honestly...you REALLY don't need it. You can get Crow 105's which what I'm guessing your talking about...OR...get a VS cam and use the factory valvetrain. Just a few options there. If you do get the Double Roller...the crank gear will have to be machined down so it doesn't crack or make contact with the oil pump cover
