unless they "look" for the cat, then you can use a hi flow cat and a deleted rear o2 sensor.
frozen boost sells a cat that is 100% free flow, its fake but looks real lol its 40 bucks. nice and cheap.
Frozen boost sells a fake cat, it looks like a cat buts just a straight pipe if they check for it.
Sent from the Milky Way
Come on Russ, this thread is getting long and complicated! Lol, keep upOh I didn't read back that far, too much reading
Easy now. Thats why I'm posting this **** on here so I don't **** up or do something I shouldn't. I've said it before and I'll say it again here, I'm accepting of feedback/suggestions both positive and negative. Havent lost my ****ing mind, looking for advice."-Replace rod bearings, again, I bought these when trying to save the old engine. Never ran them in the engine so I figure I should go ahead and stick them in here. (I know its not as simple as sticking them in there)"
HAVE YOU LOST YOUR F ING MIND??????!!!!!!!!
how about this, change the lim gaskets if they need to be changed. if metal dont touch it. change the valve cover gaskets, maybe the oil pan gasket if its wet.
forget the 180 t stat too, waste of time. does jack sh it.
dont you dare touch the bottom end, or the lifters, leave running well enough. drop it in and enjoy a running engine in your car.
Damn it, lol. Busted, for all to read. I wasn't just set straight, you beat me down man, lol. It's okay, I've recovered. Not touching the rods. Keeping all the parts though. Just to make sure the engine is running well. If all is good then they'll go back to the parts store. Thanks for setting me straight.to late, i quoted it already its there for everyone so see. lol
your not the first one thats had to be set straight. some wont listen. dont worry. just leave the rods and mains alone.
It's all good. Will probably give some a good laugh and others will shake their heads and then BillBoost will just sit back and say WTF!!! LOL. I know not to open up the mains, just guess I didn't know that I couldn't put some new bearings in it without causing issues. Lesson learned on that and my GPF education continues.i was being more sarcastic then harsh lol
thing is most think these engines are like a small block Chevy, bust it open slap new bearings in and life goes on. that dont work on a 3800. you open up the mains and the block will twist. then it needs shop work and crank work, then new bearings.
for the most part if you change the oil this engine can run for 300,000 plus. lots of us over 200,000. im one of them.
Yep, got a brand new oil pan and gasket I'll throw on it. After dropping the pan with the engine in the car, I know it is something to do while it is out..should be much easier.Now would be the time to check the oil pan for any leaks and clean it up and throw some rtv on it if needed.
