Drop by a GM dealer on this one. There is a recall out for this issue (engine fire) and if your car hasn't been done yet they will change them for free. One of mine has been done and the other two are going in some time in April. Recall number is 09047, Engine Compartment Fire.I also see that the valve cover gaskets are leaking and will replace them
They rot out as they age because they are made of rubber and there is no way to change them without pulling the intake. If they are original they will eventually leak. My 1998's went last summer so that was 12-13 years on them.Whats the deal with the coolant elbows?
They rot out as they age because they are made of rubber and there is no way to change them without pulling the intake. If they are original they will eventually leak. My 1998's went last summer so that was 12-13 years on them.[/FONT][/COLOR]
This is going to sound funny. But I AM serious.
Roll the motor forward. lots of room then.
Unbolt the 2 top mounts from the radiator side support, just 1 nut/1 bolt per mount, and swing it up and over. Then use a ratchet strap across the alternator on the support bar and then hook to the radiator support and ratchet a couple times. Motor will roll forward (won't fall tho, lower mounts will hold it in place) and give you plenty of room.
My son tore his meniscus and I was taking him to get a MRI and a Porsche pulled out in front of me and then a van pulled out in front of him and he slammed on the brakes and I couldnt stop in time so I rearended him.Care to explain the wreck?
