Ok , my car didnt have any misfires until after i changed my Lower Intake Manifold Gaskets. After changing the gaskets and putting everything back together. The car ran fine. The next day i took it an hour and 30 min away, while driving there it started misfiring and shaking,rough idle at an hour into the trip. The check engine light went to blinking. The Next day i drove it all the way back home in the condition. Put code scanner to it, and received P0303 "Cylinder 3 Misfire":
So i automatically assumed it was the coil pack because i just installed new wires and plugs a week before changing Lower Intake manifold Gasket. Bought new coil pack. Still getting rough idle and P0303 code. So i decided to take a look at Cylinder 3 Spark plug and it was dry black, carbon fouled:
So went and bought new spark plug, installed it, started car and still rough idle and misfiring. Took the new spark plug out and it had been FOULED also ( DRY BLACK AGAIN). Thats when i gave up on the problem.
Any help would be appreciated AGAIN..thanks!
SN: If i can figure this out i will fully have my car back to running correctly.
