So I had a foglight burn out last night.... upgrade time?
Advance auto special. $29 4" blazers
Uploaded with ImageShack.us
uses stock metal bracket. few aluminum spacers from ace flip the fog upside down and walla direct bolt in.
Alright. Well if anyone has before and after pics of light output with just the HID foglights that would be appriciated. Along with the color temp of the bulb.
35w 6k
I'm leaning toward 5K or 6K. Also a 55W would be brighter than a 35W and if I would go 55W would I need to rewire anything to do it?
55w also produce more heat that could potentially cause the chrome to flake (didn't see what dogs you were running and also shorten the lifespan of your bulbs. IMO if your set on hids stick to 55 watts and no you do not need to rewire it I would run a harness though.
I haven't really decided on the fogs I will be getting yet. Not going to use the stock ones for sure. I don't want to run around replacing bulbs all the time either. I may look into the 35W if that gives the bulbs more life.
I have them. The reason I got them was because I wanted a light with a clear lens. I don't have the halo's hooked up but from what I saw, they aren't that bright from far away. The halo is lit by two 194's size LEDs back to back. They perform just like any other driving light.
