real diehl
just trying to increase driveability!
Then don't modify it at all.
Those Japanese cars and many others, all have over 300+HP stock.
Correct.
I 'm wrong!
Also correct.
I 'm wrong!
You cant back up your statement, so you go from hp numbers to just wanting better drive ability.
Just for the record, I am not racing my GP, just trying to increase driveability! If I want to go racing on the street, which I don't, I would be drving a G8, GTO, G35 sedan or coupe, or IS350, and would definitely not even bother with a 97-03 GP of any type. Those Japanese cars and many others, all have over 300+HP stock. It's ok do have a differing opinion, isn't it? Or maybe, I would be wrong about that here!
What Japanese car you listed delivers over 300 horsepower there? They are all well below 300 horse after drivetrain loss...and if you really want to get technical, the 3.5 VQ35DE didn't have over 300 horse...until they came out with the 3.7 VQ37DE with the twin intake design...netted 306 to the crank...which still is well under 300 to the tire...so...I'm still waiting for dyno numbers...which after all of this BS'ing you are still avoiding...I'd told you I'd shut up if you gave me logical, photo-evidence of you gaining around 15 horsepower from a catback on a 3.1. And, since you can't...I'll never see those dyno numbers...how sad:th_shakinghead2:
Are you dense? Why would anyone dyno a cat back system on a commuter car? Do you or do you not have personal experience going from a single GP exhaust to a cat back duals on a 3.1? If you don't, at this point your comments are just heresay!
Please stop with all the chatter about crank versus advertised HP. Every car I mentioned has over 300 advertised SAE NET HP. Every car on the road has less HP at the wheels versus advertised HP due to frictional losses in the drivetrain including the beloved SC GP-240 HP, 205 HP 3.8 NA, and 175 HP 3.1L. You state that the 3.1 actually has 140 HP at the rear wheels versus its advertised 175 HP. Using your logic than the SC has 215HP at the wheels and the 3.8NA has 170 HP. Correct? Believe me, I just drove a friend's 2009 IS 350 with 306 advertised horsepower, not wheel HP, and with a documented 0-60 time of 5.7 seconds, it will whip any GP from our generation, no problem totally stock.
"Converting a car to dual exhaust with a single outlet downpipe is just stupid anyways...LOL if you think you get more power with a "Y" pipe and two mufflers when it is all still coming from the same SINGLE OUTLET DOWNPIPE"
I hate to tell you, chief, but you are wrong on this one! The limiting factor on any exhaust is the down pipe diameter, yes, but if the the system beyond that single down pipe has any restriction in it like a single restrictive muffler coupled with a single pipe after the cat, anything that increases the flow after the downpipe and reduces the restiction will help with power assuming that the downpipe diameter is not maximizing the flow for a given engine. On the other hand, if the car originally has a single downpipe with appropriate sized y pipe and mufflers, then switching to a larger more free flowing cat back system will have a minimal effect on the engines output, aka a GT/GTP. Conversely, taking a single downpipe of appropriate diameter or a front y pipe and running the exhaust through a single pipe of a larger enough diameter will produce power equivalent to a true dual exhaust. Physics here, no heresay! Sorry to disappoint!
Are you dense? Please stop with all the chatter about crank versus advertised HP. You state that the 3.1 actually has 140 HP at the rear wheels versus its advertised 175 HP
From the thirdgeneration forum:
"Re: 91 firebird 3.1L V6....more hp and acceleration?
If your not mechanically skilled, you can upgrade the exhaust(headers, catback exhaust, and hi flow cats)
Also upgrade your air intake as well as try and get rid of all the smog crap(find yourself a local inspector so you'll pass)"![]()
Would you like to eat crow, now or later?
Ok-I give up-you are right!
This has to be the most retarded person on here since the guy that thought the government was gonna take and crush our cars for running catless downpipes![]()
