barnettimpala
I have an 01 gtp that I rarely drive. I started it and let it idle after sitting for about 3 weeks. I let it run for about 15 min. It got just above the half way point on the temp gauge then would hover on half the rest of the time (fans would kick in) seems kinda high temp for just idling but idk. Anyway all of a sudden I saw smoke coming from under the hood and smelt burning oil. I shut it off and popped the hood. I couldn't tell where it was coming from but seemed to be a lot from the rear of the engine and also under the engine cover. I took the engine cover off, having to take the oil cap off and smoke was coming from inside the engine wtf??
checked oil, it's full and looks fine
coolant level is fine.
I can't really see much to see what would be leaking. Looks to be oil/grease/grime on most parts. Where the injectors go there seems to be a build up of some kind of fluid or oil in their cavities. The entire bottom of the engine and transmission is covered in oil. And there is a spot on the ground just of center to the passenger side where there is a spot of oil that has leaked on the ground.
Idk what to look for and it pisses me off. I'm trying to fix small things on the car and sell it and this happens...
Please help if you can.
Thanks!
Thanks!
