If turning the A/C off made a difference then I would suspect the A/C compressor might be locking/locked up. It will drag the belt and cause a burning smell as it smokes the belt. It can totally drag down an engine if it's not spinning with the rest of the engine, even when A/C is off, and the compressor is located at the front bottom of the engine on the passenger side.
And pro tip- to find an exhaust leak without cooking yourself, stick a shop-vac hose in the exhsust pipe tip with the vacuum set on the "exhaust" or blowing side (I always tape it tight to the exhaust) and push air into the exhuast with the car off obviously. Then you can crawl under it and feel for air leaking and fix all your leaks with no skin lost.
Where exactly did you cut off the exhaust to run the straight pipe on it? What was removed from the factory exhaust system to accompish this?
