I have drilled and slotted rotors and they do make a noise as you discribed. its so faint though you would never hear it with the windows up. only time i can hear is when driving by parked cars or a wall the sound bounces off of them.
I may do that, are the single piston worth it or the double that much better?Get the 12" upgrade, money better spent than slotted rotors.
there is no difference besides better stopping power and less brake fade
How does having slots/holes increase the coefficient of friction of your pad?
pad fade is probably what you're experiencing and that's fixed by getting higher temp pads.
If you REALLY want to cool things down, create a venting duct for your brakes. that'd really keep the fade at bay.
I have ran durulast Gold C-max pads on my car since the fiirst week I bought it. I changed over to DSR's after about a year and a half.
The drilled holes allow air to circulate through the actual brake rotor, which does intern keep temps quite a bit lower, probably as low, or lower than a vent duct could. The slots take away the smoothness of the rotor surface, and the edges create friction that helps the pads grab on better, but studies have shown that it also wears your pads down quicker. So Yes.. Better stopping power and less brake fade
