Six Speed Manual in a Grand Prix!
it was only 3 months dead and there was one about manual swap on 3800 pro people wanted info and so did i. i kinda wanny do this my trans goes out which it is gunna go sooner or later
edit: what i REALLY wanted to ask but keep forgetting was how much electronics are there that need moding to get the pcm not to freak out cuz there is no transmission to change gears
for how much custom work he did, id say either you need to be able to do your own welding/cutting/machining or you need to have a lot of money.
not the physcial moding the wireing going from a automatic to manual i dont know how the pcm could understand how the manual shifts
he had an SES on all of those videos. im not sure he did anything but tune the car and then set the codes to no report and say **** the PCM and its weak brain.
The engine still runs fine w/o the auto trans, you could delete it if you had a tuner but really you could just remove the MIL bulb and be done with it if you are cheap like me.
yes, thank you for the meaningless correction.
SES, CEL, DTC, what do you want to hear? it all means the same thing?
how did u get your trans at sucha low price
and how much would u charge to make all the mounting **** cuz i can weld cut and hammer annything into place i need to but i reall dont want to make the mounts
Are yu serious? It's a yellow light, that turns on, on yur dash panel. The right side, i believe.
The only one of my videos that has an SES light is the spoof speedo vid. One has a security light, and another has a low fuel light. And no, I wasn't quite that low in fuel, but rather my gas gauge didn't work properly.
