Shifting issues...
mick777wauchope
My 2000 GTP will not shift into 4th or overdrive when it is cold (only 40 degrees out). It takes a good 5 minutes before it would finally shift. Please help? What do I do/what could it be?
Are you sure it's not just your torque converter not locking in? Mine doesn't lock unless the motor gets to a certain temp.
You might have bigger problems then. Your 4th gear shaft could be stripping. Have you ever done a fluid and filter change?
