SES Light....Suggestions
IT's weird. I've heard of this happening. Only heard. Never got to meet anyone it actually happend to. But I ran a 160 for about a year. Through summer and winter and this never happend to me.
If it's saying the thermostat was a different temp the inside gauge then it's a bad thermostat. But in realits there is no way the PCM even know's what temp the gauge is at inside. It operates off of the Sensor it self
It happened to me all the time until I figured out how to bypass with my DHP, now granted I had a drilled t-stat as well, which will compound this issue. Only happened in the winter. I'm not saying that this "is" the problem, but could be...and it could most certainly be a bad temp sensor. If it was a bad t-stat - that usually manifests itself differently - ie; engine temp never getting up into the median range, or conversely - overheating. Stuck open, stuck closed.
Detailed info:
DTC P0128
Circuit Description
An engine coolant temperature (ECT) sensor monitors the temperature of the coolant. This input is used by the powertrain control module (PCM) for engine control and as an enabling criteria for some diagnostics.
The air flow coming into the engine is accumulated and used to determine if the vehicle has been driven within the conditions that would allow the engine coolant to heat up normally to the thermostat regulating temperature. If the coolant temperature does not increase normally or does not reach the regulating temperature of the thermostat, the diagnostics that use ECT as enabling criteria may not run when expected.
This DTC will only run once per ignition cycle within the enabling conditions. If the PCM detects the calibrated amount of air flow and engine run time have been met, and the ECT has not met the minimum thermostat regulating temperature, DTC P0128 sets.
Conditions for Running the DTC
DTCs P0101, P0102, P0103, P0112, P0113, P0116, P0117, P0118, P0125, P0502, P0503 are not present.
The startup ECT is less than 75°C (167°F).
The intake air temperature (IAT) is more than -7°C (+19°F).
The engine run time is between 30-1,800 seconds.
The vehicle is driven more than 0.8 kilometers (0.5 miles) at more than 8 km/h (5 mph).
Conditions for Setting the DTC
The PCM detects that:
The calibrated amount of engine run time has been met.
The calibrated amount of engine air flow has been met.
The calibrated vehicle speed and distance have been met.
The calibrated ECT of 80°C (176°F) has not been met.
