Service traction control soon light and abs
adamsz28
I have a 07 grand prix gt.The service abs and tc light stay on all the time. has two new hub asimblies and speed sensors on it. The wiring appears to be ok does anybody have a clue what it might be. I need help cant keep spending 90 to have the code read.
abs scan cost money almost always, its a different kind of scanner. same as a air bag scanner.
any way the last time you had it scanned? what codes did you get? and what did you do so far?
what you can do is jack up each wheel, leave the lugs tight, grab the top of the tire, and push and pull firmly, your looking to feel play in the wheel. if its loose feeling, your hub is bad.
you can also remove the plugs from the hubs, clean them with electrical parts cleaner and then dab some de electrical grease on the plug, and then work the plug off and on a few times to work the grease in.
Our cars are 4 wheel abs, maybe its one of the 2 you havent replaced.
Do you have the codes from when you got it scanned before and you've been replacing the wrong ones this whole time?
