seafoamed my car no smoked
Mirraco
One BadAzz GT Dawgg
I seafoamed my 04 gt2 with 165K miles today.
I did not notice much of any smoke from engine, i put it straight into vacuum line. I used roughly 1/3-1/2 a bottle, let it sip about half of it, and quickly added the rest of it. let it sit for around 20-25 minutes then started but no smoke.
I did notice a little extra smoke from the exhaust right before i let it take the last of the seafoam, what did i do wrong
Use a full can and make it chug it to the point of dying, then let it die, let see, varooooooooom
I had same issue did it at @00,000 and 300,000 but was thinking I am original owner an always change oil air filter plugs wires etc at recommended intervals an slick 50 every 50,000 so that may be why
it could be really clean i suppose, i had my father keep it revved at 2000 rpm so it didnt die and then told him to kill it when i finished the last few oz. I drove the car like i stole it for a good 10 minutes.
you did it all wrong.
you let it suck the sea foam in at idle. then dump a bunch in to stall it. then wait 20 minutes and fire it up.
just pull the brake booster line off, pinch it so the car runs, then pour the sea foam in the hose. open the hose all the way and let the last chug suck in to stall it.
Wrong dont use the brake booster hose it only gets to 3 cylinders. Take the vac t off under the left side of intake and put a scrap hose to that.
You were already told you were wrong about this in another thread just last week...
I forget where i read this on this forum, but i did and tried seafoaming it threw the inlet under the intake after and seen WAY more smoke. so idk
