Satellite Radio
I am not sure if the factory radio will have the necessary XM connections to work with that tuner. Have you pulled the radio to check? Either way you will need an antenna for the XM to work.
If your deck is an 03 or newer it will work, however you will have to add connectors to hook it up...not very big of a job if your electrically knowledable. you can simply get an onstar antenna with xm built in...these will have 3 seperate connectors the two seperate connectors for onstar and a third for xm.
Used XM Modules...upon installation you will get the xm locked message as soon as the key reaches the on position...the dealer themselves CANNOT clear theft lock on xm modules...headunits they can though.
So what needs to be done is the module either be sent to a delphi service center to clear the eeprom or purchase a new module from the dealer...
I installed factory XM twice on grand prixs, first was on my 04 i got lucky and got a new module on ebay, however that car got wrecked so i did the same thing on my replacement 06 and ended up having to buy a new XM Module.
I think yours is an 05 which i think it is, you have the class 2 data bus so the module must be meant for vehicles like an impala03-05, grand prix, up until 06 silverados and sierras, canyons and colarados and equinoxes. pretty much everything else is GM LAN.
Actually I found a nice list, any one of these and they will work...
EQUINOX 06 SAT recvr (opt U2K), ID 10333560
MONTE CARLO 05 SAT recvr (opt U2K), ID 15125061
UPLANDER 07 SAT recvr (opt U2K), w/Multi media-Audio/Video/Videogame (opt UMS)
ALLURE 05 SAT recvr (opt U2K)
CTS 05 SAT recvr (opt U2K), ID 10333560
MONTANA 06 (SV6), SAT recvr (opt U2K), ID 15125061
RELAY 05 SAT recvr (opt U2K)
SILVERADO 2500 PICKUP 04-05 SAT recvr (opt U2K)
TORRENT 06 SAT recvr (opt U2K), ID 15125061
YUKON XL 1500 04-05 SAT recvr (opt U2K)
SIERRA 1500 PICKUP 04-05 SAT recvr (opt U2K)
SIERRA 2500 PICKUP 04-05 SAT recvr (opt U2K)
SUBURBAN 2500 04-05 SAT recvr (opt U2K)
UPLANDER 05 SAT recvr (opt U2K)
EQUINOX 06 SAT recvr (opt U2K), ID 15125061
TERRAZA 07 SAT recvr (opt U2K), w/Multi media-Audio/Video/Videogame (opt UMS)
YUKON XL 2500 04-05 SAT recvr (opt U2K)
AVALANCHE 2500 04-05 SAT recvr (opt U2K)
LACROSSE 05 SAT recvr (opt U2K)
MONTANA 07 (SV6), SAT recvr (opt U2K), w/Multi media-Audio/Video/Videogame (opt UMS)
UPLANDER 06 SAT recvr (opt U2K), ID 15125061
SRX 05 SAT recvr (opt U2K)
SILVERADO 1500 PICKUP 04-05 SAT recvr (opt U2K)
GRAND PRIX 07 SAT recvr (opt U2K), ID 15125061
SILVERADO 3500 PICKUP 04-05 SAT recvr (opt U2K)
YUKON 04-05 SAT recvr (opt U2K)
AZTEK 05 SAT recvr (opt U2K)
ESCALADE 04-05 SAT recvr (opt U2K)
ESCALADE EXT 04-05 SAT recvr (opt U2K)
TERRAZA 06 SAT recvr (opt U2K), ID 15125061
ESCALADE ESV 04-05 SAT recvr (opt U2K)
RENDEZVOUS 04-05 SAT recvr (opt U2K)
TAHOE 04-05 SAT recvr (opt U2K)
TORRENT 06 SAT recvr (opt U2K), ID 10333560
MONTANA 05 SV6, SAT recvr (opt U2K)
AVALANCHE 1500 04-05 SAT recvr (opt U2K)
IMPALA 05 SAT recvr (opt U2K), ID 15125061
CTS 05 SAT recvr (opt U2K), ID 15125061
SIERRA 3500 PICKUP 04-05 SAT recvr (opt U2K)
SIERRA DENALI 04-05 SAT recvr (opt U2K)
SUBURBAN 1500 04-05 SAT recvr (opt U2K)
RELAY 06-07 SAT recvr (opt U2K), ID 15125061
TERRAZA 05 SAT recvr (opt U2K)
Theres a company called instrument sales and service or somethign like that mentioned on this link that reflashes the eeprom on the modules...
"XM Lock", "XM Locked", or "XM Theftlocked" Issue Resolved! - Corvette Forum
I walked a guy through installing xm on his prix and this is the route he took...worked perfect for him.
Heres the thread on installing XM on a prix, connectors arnt the same in certain parts of the car since its a grand prix but there is alot of valubale information otherwise.
Grand Prixs Of North America • View topic - Factory XM install????
Do you have access to wiring diagrams and such for your ss? if not I can get some.
Thanks for the info, no I don't have the wiring diagram and would appreciate your help in area as well.
