T
TDCRacing
Guest
I Will have about all I can to help with oiling such as the Intense oil pressure kit,Balance shaft removed and plugged,Oil return holes drilled ect ect.
I am hoping to get some input from you turbo guys since i'm sure you guys are the main ones that are running high rpm's. But anyone who knows i'd also like you're opinion.
My cam's power range will be from about 3500 to 7500. Or so it says.
So i'll likley be shifting around 7500.
It will also be a fully rebuilt motor.
What i'm mainly wanting to find out is What the title says. What is safe as in if I do it a lot will it reduce my motor life by an EXTREAM amount?
