S/C Belt for I/C setup?
bbptech
Which supercharger belt do i need to get for my car that will have a full size intercooler on it? It'd be great if i can get some part numbers.
Depends.... Whats the height of the core? Do you have an oversized tensioner? What pulley will you run? Its a very open ended question.
They easiest thing too do IMO, once you get the car together, drive to you're local autoparts store, try out 60"+ belts about .5" from each other and get the one that fits the tightest. I had to do this because my setup is a bit more complicated. I'm running a 2" tall IC, PC belt wrap Kit, Oversized tensioner pulley, and a 2.9". IIRC, i'm running a 66.5" belt.......
Have someone max the tensioner out and wrap a string around your setup and then measure the string. Then go to the parts store and ask for the closest belt equivalent or slightly longer.
I tried the string trick before, I think its much easier just driving up there and trying them out so you can get the absolute tightest fit
My belt is as tight as a virgin on prom night...
ill end up having to do the string trick. I live 8 miles away from the nearest auto parts store so i can necesarily just drive my car there for test fitting belts. It should basically be 2.25 inches more than the belt im running since thats how tall the intercooler is. Using stock belt with all sock pulleys besides 3.4 Supercharger pulley.
