RX330 retrofit into 2007 Grand Prix GXP.
Just because I'm lazy and don't feel like going back let me get this straight. Murano in the low beam. RX in the highs. Fusion fogs. Which shroud you using?
For the Murano, I'm using the Apollo 2.0 with a 100mm(?) xBa LED behind it. It's like the shrouds were made to fit specifically the Murano's, they literally would not need any way of securing them if I didn't want to as they push on perfectly and stay stationary.
And for the RX's, I decided to use an Apollo 1.0 with NO xBa. I wanted to keep some sort of uniformity when I was choosing the shrouds for them.
I do not, good sir. :(
And I have something else in mind for my reverse lights, but it's hush-hush for now. ;)
Why you no share secrets with me :(
Darn it. Needed to see how the Gatling gun covers the RX I have a dummy headlight that I use to hack up and wanted to go ahead and have a plan in mind to get then mounted and flush with the shroud.
In due time, my friend. :)
And I would just post a WTB thread on HIDP to see if anyone has a spare one they can let go for cheap. I'd definitely hook you up if I had one laying around..
Don't be surprise if your lead into a conference room and a intervention starts..jus sayin.
Lmao, it's like crack to me. You know, since the GXP is next to useless with much else aftermarket. I have to make do on lighting, rather.
That's true. I have so many other projects going on I turned my back on the next retrofit for the time being but it will come.
