Rtv on gaskets
rickisrad
Just wondering whether or not you guys use RTV or sealant on the intake end cap and also the oil filter adapter gasket??
I use rtv on my end cap gasket, I'm not sure what difference it makes, but in my head I like doing it because when I open up the coolant passage, almost always I nick the outside edge.
I'll put a thin layer of thermostat housing sealant on the end cap seal. I didn't open it up as much as some people do. I'll do some more searching on the filter adapter gasket.
I used to spread a thin layer of silicone type gasket maker on a lot of gaskets probably due to a lack of confidence. Then started using this spray tack stuff...
https://www.napaonline.com/en/p/BK_7651224
It works really well and its not messy as long as you have a piece of cardboard or something to lay the gasket on and spray it. I recently resealed my entire motor and the only gasket maker I used was on the intake corners. No leaks so far.
Intake stuff near the throttle body is usually installed dry. I used the spray on the oil filter adapter.
I use rtv instead of a supercharger gasket. I did the end cap seal with just rtv because I went a too close when I opened up the coolant flow, no problems. Oil filter adapter i always do dry, with ptfe paste on the bolts.
