Swiggles
Donating User
Will rtv cure properly when it’s super cold out? My garage isn’t heated and it’s going to under 20 degrees out all next week. I’ve got a coolant leak either from the lim gaskets not having enough on the corners or from the coolant plugs in the lim that I tapped a little too wide.
I use gray rtv instead of a supercharger gasket because I always get a vac leak no matter what gasket I use so I stopped using them.
