loopy smurf
Wait - you have uneven wear on your pads? Did you push the caliper piston all the way in? If you have uneven wear on your pads, you probably have a bad caliper...especially if you are unable to recess the piston...
So I'm talking about the knuckle.
One of the bolts was over screwed in. Which pressing the brake too tight on one side. Which is wrong cz the other bolt of the knuckle is screwed all the way but fine. But the bolt on the right side is over screwed. I opened it a little bit so it will be even.
im confused, post a pic of what your talking about. if you can.
