    TIPS:
Roof Rack
Speedy1973
Selling a roof rack I've had on my GP for a while now. No longer want/need it. Surely someone else can put it to good use. It's Sportrack Brand, with square bars, and was modified slightly to work on the roof of my GTP. It does show use of wear and tear, and obvious signs of being out in the elements! One of the end caps that house the lock, is MISSISNG! I do have the other 3, aswell as the key to remove them. You can Buy replacement cap's and locks online. Aswell as a wind fairing.
When installed, the feet clear the roof "gutters" and could be used with a set of Roof Rails!
Depending on placement on your roof line, it may or may not cause a clearance issue with the sun roof. I had it mounted so the sunroof would clear the rear bar. BUT just barely...
Located in Bancroft, ON
Price: $120
Photo's will be posted shortly!!
