Hey guys whats up? I'm looking to put some 22 inch rims on my 2004 grand prix gtp....does anybody know will they fit and what modifications, if any will I need for them to fit properly?
Well Im looking for some used ones on craigslist, but I dont wanna buy them if they wont fit, so Im trying to figure out exactly what size will fit so I can start searching for some that might work
- bolt pattern is 5x115, 5x114.3 works
- run the same overall diameter tire as stock, use a tire size calculator to see what sizes you want
- for 22s youll probably want an offset of around +40mm to make sure you clear everything
- you may need a little fender rolling, which isnt too bad if you know what youre doing
I'd lower it...I'd also make sure...if you go with the 22's...your transmission is in good shape because that much rotating mass on a 4T65E = not so great on the trans...20's however...aren't THAT bad...IMO, I'd never go past 18's...but if you get the right wheel...20's can be pulled off pretty well.
