ribbed for my pleasure.....
BBluelandyacht
what is the advantage of upgrading to an 8rib pulley setup?
and when do i do it? is there a certain point in modding where it is needed?
Do it because you have belt slip, not as a preventative measure. If you don't have belt slip, don't worry about it. The additional weight over a 6-rib will (theoretically) get you slightly worse gas mileage, although if you got them done in billet aluminum, it might be about the same as the stocks.
